Group: DynoMotion Message: 7719 From: Toby Rule Date: 6/20/2013
Subject: SetBit m-codes not working
I just switched to KMotion431e.  I’m finding that under certain conditions, the set-bit m-codes are not working.  For instance, if I set the following in my C# code, in order to configure M106 and M107 to goggle bit 50 on and off ...
kmInterpreter.SetMcodeAction(21 + 106 - 100, KMotion_dotNet.MCODE_TYPE.M_Action_Setbit, 50, 1, 0, 0, 0, "");
kmInterpreter.SetMcodeAction(21 + 107 - 100, KMotion_dotNet.MCODE_TYPE.M_Action_Setbit, 50, 0, 0, 0, 0, "");
… and then run the following program ...
g0 x0 y0
m106
g1 x10 y0
m107
g0 x0 y0
m106
g1 x10 y0
m107
g0 x0 y0
m106
g1 x10 y0
m107
g0 x0 y0
m2
... bit 50 only toggles on, then off, and then it doesn’t toggle any more after line 5.
If I replace the g0 commands with g1 commands, then the bits toggle correctly.
Group: DynoMotion Message: 7720 From: Toby Rule Date: 6/20/2013
Subject: Re: SetBit m-codes not working
HI Tom,
I found that I get the same result when I use (Buf,SetBitBuf50) and (Buf,ClearBitBuf50) instead of M106 and M107.
Toby
Group: DynoMotion Message: 7732 From: Tom Kerekes Date: 6/21/2013
Hi Toby,
Please see if this Patch resolves the issue:
http://dynomotion.com/Software/Patch/FixEmbbededIOwRapid431f/GCodeInterpreter.dll
http://dynomotion.com/Software/Patch/FixEmbbededIOwRapid431f/CoordMotion.cpp
Thanks for the clear example.
Group: DynoMotion Message: 7762 From: Toby Rule Date: 6/24/2013
That does the trick.  Thanks for the quick response!
I can see that you’ve been making lots of changes to GCodeInterpreter.dll.  While you’re at it, can you add a method to calculate the currently-executing g-code line?  I’m still patching your version with a function to do this, and based on our previous discussions, I think the code I’m using is likely to break in the event of a coordinated motion operation long enough to cause the buffer to circle around.  My code is pre-circular-buffer.
Toby
Group: DynoMotion Message: 7901 From: Toby Rule Date: 7/10/2013
I found that although the patch fixed the SetBit case, if I do SetTwoBits, it still doesn't work.  If I set the MCodeAction as below, and then run the program from my previous example, the bits toggle on, then off, and then they don't do anything for the rest of the program.
            kmInterpreter.SetMcodeAction(21 + 106 - 100, KMotion_dotNet.MCODE_TYPE.M_Action_SetTwoBits, 50, 1, 51, 1, 0, "");
            kmInterpreter.SetMcodeAction(21 + 107 - 100, KMotion_dotNet.MCODE_TYPE.M_Action_SetTwoBits, 50, 0, 51, 0, 0, "");
Toby
Group: DynoMotion Message: 7907 From: Tom Kerekes Date: 7/10/2013
Hi Toby,
I tested setting Two bits from KMotionCNC and I can't see a problem.
Maybe there is an issue with the Patch.  Here is a complete new Test Version.  Please try it so we know we are using the exact same code.
http://dynomotion.com/Software/KMotion431g.exe
Sent: Wednesday, July 10, 2013 2:38 PM
Subject: RE: [DynoMotion] RE: SetBit m-codes not working
Toby
Group: DynoMotion Message: 7911 From: Toby Rule Date: 7/11/2013
My mistake! I was linking to the wrong, unpatched version of KMotion.
Toby
